moyhall
#1 Posted : Tuesday, October 13, 2009 5:22:17 PM(UTC)
moyhall
the relay was stuck and chipping the breaker , after changing the relay and
overload it to clicking and fridge not cooling
applianceman
#2 Posted : Tuesday, October 13, 2009 5:37:00 PM(UTC)
applianceman
You may have a bad compressor. Was the overload tripping before you replaced it or was the breaker on in you house wiring tripping? If you have an ohmmeter check resistance between each of the terminals on the compressor with the relay and the overload disconnected. Also check for continuity from each terminal to ground. If you get any reading at all to ground the compressor is bad. Post what you find. Refrigerator repair guide
moyhall
#3 Posted : Tuesday, October 13, 2009 5:53:42 PM(UTC)
moyhall
we found the fridge off and we discover the breaker tripped we put back on
the breaker plug the fridge in and it tripped breaker again we discover that
it was overload and relay was tripping the breaker that why we change them
after changing them the fridge starting the clicking and not cooling
applianceman
#4 Posted : Tuesday, October 13, 2009 8:27:54 PM(UTC)
applianceman
I believe the compressor is bad if you have an ohmmeter do the test I describe above and post results.
The only thing is, that test is only checking the compressor electrically. The compressor could still be bad even if it passes the test. However, if the start relay was bad, you replaced it and the compressor still will not start I would say the compressor is bad.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest 1/11/2024 5:03:35 AM(UTC)
GE fridge, Evaporator Heater fried (Refrigerator & Freezer Repair)
by Guest 9/23/2023 8:19:17 AM(UTC)
Freezer is not cooling, fan is not working, light not on, NEW control board; GE fridge GSS25GSHJCSS (Refrigerator & Freezer Repair)
by Guest 8/6/2023 3:06:23 PM(UTC)
Freezer fan doesn't work, new control board; GE fridge GSS25GSHJCSS (Refrigerator & Freezer Repair)
by Guest 8/6/2023 3:02:45 PM(UTC)
GE Fridge - no ice (Refrigerator & Freezer Repair)
by Guest 1/22/2023 8:39:51 AM(UTC)
Replacement freezer gasket for GE Fridge GSS25JFMAWW (Refrigerator & Freezer Repair)
by Guest 11/13/2022 8:12:45 AM(UTC)
Monogram GE fridge (Refrigerator & Freezer Repair)
by Guest 8/23/2021 5:24:17 AM(UTC)
GE fridge front control panel is off (Refrigerator & Freezer Repair)
by frank1979 4/5/2021 10:10:58 PM(UTC)
gsl22jftabs ge fridge nit runnubg after power outage yesterday (Refrigerator & Freezer Repair)
by Guest 3/25/2021 7:14:05 AM(UTC)
GE Fridge model CFSP5RKBBSS - No Icecubes (Refrigerator & Freezer Repair)
by HaroldS 2/13/2021 2:17:30 PM(UTC)
33 year old GE fridge not cooling (Refrigerator & Freezer Repair)
by stevebass 7/11/2020 4:05:50 PM(UTC)
GE fridge - frost in ice cube dispenser (Refrigerator & Freezer Repair)
by rchrdm 4/13/2020 4:06:53 PM(UTC)
GE fridge has 20kHz audible noise (Refrigerator & Freezer Repair)
by mprmeyer 4/9/2020 7:47:39 AM(UTC)
Do NOT buy WR24X10302 or WR24X10296 for GE fridge. (Refrigerator & Freezer Repair)
by apmin 2/21/2020 7:35:36 AM(UTC)
