AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Auto clean plus button not working, dry light on, steam clean blinking
Replaced control board after viewing many blogs. Same problem. When I start any cycle the "steam clean" light blinks. Also the "Dry" light comes on. The "auto clean plus" button will not function. When I do the reset (pressing hi temp wash, heat dry, hi temp wash, heat dry) machine runs through a quick drain cycle then all lights light up except "wash" light and "cancel" light. What's broken?
Hello craigs_smith!
I'm wondering if you found the solution for your problem with the dishwasher. What was wrong? What were your troubleshooting steps? I'm having exactly the same issue.
Thanks, Kola Balabo
Kola, No I have not fixed the issue. My machine will run just fine on normal, heavy and other cycles, but not the Auto Clean Plus cycle. As I said I replaced the main control circuit board, but not the control panel. I have done all the different resets (High temp, cancel, high temp.... ) and power it off for several hours. At some point I will try to clean the leads to the control panel, but at this point the machine cleans well so I don't want to cause additional problems. Craig Originally Posted by: kolabalabo ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hello craigs_smith!
Thanks, Kola Balabo
Hello Craig,
Thanks for your reply. In addition to the problem you described my dispenser door is not opening so I have to open if manually after the machine finishes pre-wash and drains the water. Will keep looking for the root cause and let you know if I find it.
Kola
Dishwasher Repair
