craigs_smith@msn.com
#1 Posted : Tuesday, December 3, 2013 10:36:35 AM(UTC)
Replaced control board after viewing many blogs. Same problem.
When I start any cycle the "steam clean" light blinks. Also the "Dry" light comes on. The "auto clean plus" button will not function.
When I do the reset (pressing hi temp wash, heat dry, hi temp wash, heat dry) machine runs through a quick drain cycle then all lights light up except "wash" light and "cancel" light.
What's broken?
kolabalabo
#2 Posted : Thursday, January 23, 2014 8:39:30 PM(UTC)
kolabalabo
Hello craigs_smith!
I'm wondering if you found the solution for your problem with the dishwasher. What was wrong? What were your troubleshooting steps? I'm having exactly the same issue.
Thanks,
Kola Balabo
#3 Posted : Sunday, January 26, 2014 6:36:28 PM(UTC)
Kola,
No I have not fixed the issue. My machine will run just fine on normal, heavy and other cycles, but not the Auto Clean Plus cycle. As I said I replaced the main control circuit board, but not the control panel. I have done all the different resets (High temp, cancel, high temp.... ) and power it off for several hours. At some point I will try to clean the leads to the control panel, but at this point the machine cleans well so I don't want to cause additional problems.
Craig
Originally Posted by: kolabalabo Go to Quoted Post
Hello craigs_smith!
Thanks,
Kola Balabo
kolabalabo
#4 Posted : Sunday, January 26, 2014 8:15:56 PM(UTC)
kolabalabo
Hello Craig,
Thanks for your reply. In addition to the problem you described my dispenser door is not opening so I have to open if manually after the machine finishes pre-wash and drains the water. Will keep looking for the root cause and let you know if I find it.
Kola
