mebukat
#1 Posted : Monday, November 25, 2013 10:08:18 AM(UTC)
mebukat
I have a Whirlpool ED5PHEXRQ00 that is going on 10 yearsold. When the unit is in a cooling cycle (running) the outside front-facing surfaceof the cabinet on the freezer side is HOT (130 degrees). This is where thefreezer door seals against the cabinet. When the unit is not running there isno heat. I hate to think I have never noticed this before. As far as I can tellthe unit functions normally (no frost build-up, no excessive running). I canfind no reference to this in the users manual or any parts diagram showingheater strips along these edges. Is this heating normal?
Appliance Ninja
#2 Posted : Monday, November 25, 2013 10:29:00 AM(UTC)
Appliance Ninja
The condenser fan in the back of the cabinet, behind the lower panel, is not working. If you remove that panel from the compressor area, you will likely find it is not moving. If there is nothing stuck in the blades, the motor will likely need to be replaced. You can test it to see if it is getting voltage, if you have a meter. The motor kit is available below if you find it necessary to replace.
Whirlpool W10124096 Condenser Motor Kit - AppliancePartsPros.com
mebukat
#3 Posted : Monday, November 25, 2013 11:54:36 AM(UTC)
mebukat
You nailed it. I removed the rear cover and the fan was not turning. I spun the blade and it started spinning. After several minutes the hot surfaces in front started to cool. When the cooling cycle finishes I'm going to give the underside a thorough cleening then monitor it for awhile. Never seen this before so wasn't sure if it was a real problem or me not paying attention.
Appliance Ninja
#4 Posted : Monday, November 25, 2013 12:08:05 PM(UTC)
Appliance Ninja
It is hard on the compressor for it to get that hot, so if it stalls again, replace that fan. Nice work tracking it down! Have a great week!
