AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
My dryer wont stop running, the front panel lights wont work and it doesnt heat
My dryer will not stop running, panel doesn't light up and it doesn't heat. It was working fine until the installer switched the cord from a 3 prong to 4. I heard a pop when he plugged it in. He left and said he would be back to fix it but has yet to return my calls or return
You have been a member since:: 2/29/2008(UTC) Posts: 19,638
Here are your parts Parts for Frigidaire AEQ7000EG0 Dryer - AppliancePartsPros.comHere is the tech sheet http://manuals.frigidaire.com/p...r/134682200ts_wd_EFS.pdfHere is the install sheet. It has info on 3 and 4 wire hookups so you can check to see what if anything the installer did incorrectly. http://manuals.frigidaire.com/p.../Webster/134759900es.pdfYou did not say why the cord was being replaced but it would be a good idea to also check that the wall receptacle is wired correctly. Could be you lost half the line (the L2 side). First I would check to see if the unit is wired OK for 4 wire. Unit unplugged. Then check power at the receptacle etc. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"]Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
That did not work. The dryer still runs without any lights on the front panel and doesn't heat. The only way to stop it is to turn the breaker off. The wiring for a 4 way is correct; ie the colors match.
Sounds like the control board is shot. |
Dryer Repair
