VRF201
#1 Posted : Tuesday, October 13, 2009 8:11:00 AM(UTC)
VRF201
Hi and Hello to all!
I have a Whirlpool model refrigerator GS6NVEXSL01 that the freezer is working ok (zero degrees), but the refrigerator side is 50 degrees.
I believe it is the same problem (defrost issue), but I don't know what part to replace?
Currently the controls according to the manual are to be set at 4 and 4, but I have the controls now set at 6 and 7 still doesn't work.
Thanks for any help on this matter!:)
Roy
#2 Posted : Thursday, October 15, 2009 4:03:22 AM(UTC)
Replacement parts for WHIRLPOOL GS6NVEXSL01 | AppliancePartsPros.com
Before assuming it is a defrost problem make sure that the evaporator fan is running.
This is required to push the cold air from the freezer into the fresh food section.
Also check that the damper (louvers) between the freezer and fresh food are opening.
If both the above are OK then remove the evaporator covers and check the coils, if they are heavily iced/frosted over then you have a defrost problem.
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%202303922.pdf
Try forcing a defrost cycle.
If the defrost heater comes on then the board is probably shot.
Be careful not to burn your fingers!!!
If no heat then check the defrost heater and the defrost thermostat with a meter.
Note that the defrost thermostat must be frozen to give 0 ohms, it opens just above freezing.
If both OK then you could check if they are receiving power as it may still be a board problem.
Here are a couple good sites with troubleshooting help.
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
