Replacement parts for WHIRLPOOL GS6NVEXSL01 | AppliancePartsPros.comBefore assuming it is a defrost problem make sure that the evaporator fan is running.
This is required to push the cold air from the freezer into the fresh food section.
Also check that the damper (louvers) between the freezer and fresh food are opening.
If both the above are OK then remove the evaporator covers and check the coils, if they are heavily iced/frosted over then you have a defrost problem.
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%202303922.pdfTry forcing a defrost cycle.
If the defrost heater comes on then the board is probably shot.
Be careful not to burn your fingers!!!
If no heat then check the defrost heater and the defrost thermostat with a meter.
Note that the defrost thermostat must be frozen to give 0 ohms, it opens just above freezing.
If both OK then you could check if they are receiving power as it may still be a board problem.
Here are a couple good sites with troubleshooting help.
http://www.applianceaid.com/refrigerator.html Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.comIf you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
