I really like this laundry center. One month ago the dryer would scream or squeal until it got hot then it would quit. This past Saturday it made a super high pitch scream that would not stop. There is nothing else unusual in the units operation. Please tell me what to do.
Your problem is probably in the rear bearing assembly. There is a parts kit which you can get by calling the APP folks, or you can get it from any other repair parts store as this is a common failure for the Frigidaire dryer as either a stand alone or as part of a laundry center.
While you have it apart to change it out I would also change out the belt and idler assembly, and you should be all set.
