Linnee' Davis
#1 Posted : Tuesday, October 13, 2009 6:18:03 AM(UTC)
Linnee' Davis
I really like this laundry center. One month ago the dryer would scream or squeal until it got hot then it would quit. This past Saturday it made a super high pitch scream that would not stop. There is nothing else unusual in the units operation. Please tell me what to do.
sidfink43
#2 Posted : Wednesday, October 14, 2009 6:39:27 AM(UTC)
sidfink43
Your problem is probably in the rear bearing assembly. There is a parts kit which you can get by calling the APP folks, or you can get it from any other repair parts store as this is a common failure for the Frigidaire dryer as either a stand alone or as part of a laundry center.
While you have it apart to change it out I would also change out the belt and idler assembly, and you should be all set.
My dryer is screaming! (Dryer Repair)
by Kakes 10/7/2013 12:19:34 PM(UTC)
