cooktop light stays on when controls are turned off. What could be the problem?
The light that stays on, is it one that is lit only when a surface is turned on or one that means a burner is hot?
Originally Posted by: Appliance Ninja  The light that stays on, is it one that is lit only when a surface is turned on or one that means a burner is hot? when the surface is turned on not the hot surface light
Okay, so one of the switches has a welded pilot contact. Do you have a meter to test with?
