teobrn
#1 Posted : Tuesday, November 19, 2013 11:52:08 AM(UTC)
teobrn
cooktop light stays on when controls are turned off. What could be the problem?
Appliance Ninja
#2 Posted : Tuesday, November 19, 2013 11:55:03 AM(UTC)
Appliance Ninja
The light that stays on, is it one that is lit only when a surface is turned on or one that means a burner is hot?
teobrn
#3 Posted : Tuesday, November 19, 2013 12:06:13 PM(UTC)
teobrn
when the surface is turned on not the hot surface light
Appliance Ninja
#4 Posted : Tuesday, November 19, 2013 12:08:22 PM(UTC)
Appliance Ninja
Okay, so one of the switches has a welded pilot contact. Do you have a meter to test with?
GE Range hot cooktop light stays on (Oven Repair (including Ranges and Cooktops))
by serious888 7/1/2014 7:57:49 AM(UTC)
Cooktop Light Stays On (Oven Repair (including Ranges and Cooktops))
by ApplianceGirly 1/23/2013 3:36:40 PM(UTC)
