rcarman57
#1 Posted : Thursday, November 14, 2013 1:11:33 PM(UTC)
rcarman57
:eek: After A Load Of Wash, Still Had Water In Bottom.
I Tried To Run An Empty Load To Drain And It Would Not Turn On... No Lights Or Power.
The Tub Is Filling With Water And When Front Door Is Opened Water Pours Out.
I Shut Off Water Lines And Drained Out Tub!!
Help, :confused:
Rick
Appliance Ninja
#2 Posted : Thursday, November 14, 2013 1:23:00 PM(UTC)
Appliance Ninja
Was the machine filling even when the control was off? The control will do nothing at all, no beeps or lights at all?
rcarman57
#3 Posted : Thursday, November 14, 2013 4:32:01 PM(UTC)
rcarman57
Yes, it was filling up "No Power" no beeps or lights! Dryer on same Quad outlet and still has power to controls...
Thanks,
Rick
Appliance Ninja
#4 Posted : Thursday, November 14, 2013 4:37:51 PM(UTC)
Appliance Ninja
Okay, so if you unplug the washer and turn the water back on, does it fill now?
rcarman57
#5 Posted : Thursday, November 14, 2013 4:47:58 PM(UTC)
rcarman57
iI am at work, I will try when I get home.
Thanks,
Rick
Appliance Ninja
#6 Posted : Thursday, November 14, 2013 4:56:01 PM(UTC)
Appliance Ninja
Sounds good, keep me posted. I suspect the valve is faulty and allowing water to leak by, but that test will prove it. As far as the control, it may have issues but let's deal with that after we get the water thing figured out.
rcarman57
#7 Posted : Thursday, November 14, 2013 5:17:53 PM(UTC)
rcarman57
Thanks Ninja, I will post results tonight!
Appliance Ninja
#8 Posted : Thursday, November 14, 2013 5:18:49 PM(UTC)
Appliance Ninja
Thank you!
