:eek: After A Load Of Wash, Still Had Water In Bottom.
I Tried To Run An Empty Load To Drain And It Would Not Turn On... No Lights Or Power.
The Tub Is Filling With Water And When Front Door Is Opened Water Pours Out.
I Shut Off Water Lines And Drained Out Tub!!
Help, :confused:
Rick
Was the machine filling even when the control was off? The control will do nothing at all, no beeps or lights at all?
Originally Posted by: Appliance Ninja  Was the machine filling even when the control was off? The control will do nothing at all, no beeps or lights at all? Yes, it was filling up "No Power" no beeps or lights! Dryer on same Quad outlet and still has power to controls... Thanks, Rick
Okay, so if you unplug the washer and turn the water back on, does it fill now?
Originally Posted by: Appliance Ninja  Okay, so if you unplug the washer and turn the water back on, does it fill now? iI am at work, I will try when I get home. Thanks, Rick
Sounds good, keep me posted. I suspect the valve is faulty and allowing water to leak by, but that test will prove it. As far as the control, it may have issues but let's deal with that after we get the water thing figured out.
Originally Posted by: Appliance Ninja  Sounds good, keep me posted. I suspect the valve is faulty and allowing water to leak by, but that test will prove it. As far as the control, it may have issues but let's deal with that after we get the water thing figured out. Thanks Ninja, I will post results tonight!
