I have a Gibson gas dryer. When I turn the start knob, I hear a hum but the drum does not turn. Any suggestion is wha is wrong and how to fix it?
The motor is likely faulty but it is possible that something is in the blower. Can you manually turn the tub or is it very difficult?
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The motor is likely faulty but it is possible that something is in the blower. Can you manually turn the tub or is it very difficult? It is very difficult to turn the tub.
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The motor is likely faulty but it is possible that something is in the blower. Can you manually turn the tub or is it very difficult? It is difficult to turn the tumbler.
Can you remove the lint filter and have a look at the very bottom of the filter housing? That is where the blower wheel is. Do you see anything at the very bottom, like a sock or rag, that may be keeping the blower from turning? If not, the motor is likely faulty. Let me know what you see in the housing.
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Can you remove the lint filter and have a look at the very bottom of the filter housing? That is where the blower wheel is. Do you see anything at the very bottom, like a sock or rag, that may be keeping the blower from turning? If not, the motor is likely faulty. Let me know what you see in the housing. Now I have another twist. The dryer starts a couple of times and then won't start. If I leave it for several hours it may or may not start again. I also checked the filter housing. There wasn't any rag or sock, but I did have lint (which I removed, dryer won't start.)
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks for your help. I guess I will replace the belt as well.
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I am replacing the motor. How do I get the blower wheel off of the motor shaft?
