I just replaced the pressure sensory on this machine and now it is showing an F35 code and sud code still. Any ideas what this could be or where i might find the answer?
If you have replaced the pressure sensor already, the issue lies with the cables from the sensor to the control or the actual control itself. If the cable looks good, the control is likely faulty. If you post the complete model number, I can get you the correct part number.
