char993
#1 Posted : Tuesday, November 12, 2013 9:03:13 AM(UTC)
char993
I just replaced the pressure sensory on this machine and now it is showing an F35 code and sud code still. Any ideas what this could be or where i might find the answer?
Appliance Ninja
#2 Posted : Tuesday, November 12, 2013 9:05:56 AM(UTC)
Appliance Ninja
If you have replaced the pressure sensor already, the issue lies with the cables from the sensor to the control or the actual control itself. If the cable looks good, the control is likely faulty. If you post the complete model number, I can get you the correct part number.
char993
#3 Posted : Tuesday, November 12, 2013 11:15:17 AM(UTC)
char993
Appliance Ninja
#4 Posted : Tuesday, November 12, 2013 11:21:05 AM(UTC)
Appliance Ninja
Thank you! The board I believe you will need to replace (if all connections are verified okay) is available at the link below.
Whirlpool W10157911 Cntrl-Elec - AppliancePartsPros.com
