PinWizard
#1 Posted : Saturday, November 9, 2013 7:45:12 AM(UTC)
PinWizard
My apologies for posting the same question that has probably been answered many times here...after searching I couldn't find my issue.
The agitator in my single belt Maytag continues to oscillate during the spin cycle, doesn't "disengage" and allow fast spinning as it should. I would like to think that I need a new thrust bearing kit but wanted to make sure I don't have other/additional problems. If the tranny is bad for example, I'm not going to attempt a repair as it's not worth it.
-belt is good
-brake is good
-no obstructions
-drains fine
-no squeaks, leaks or grinding
Thanks for your time.
fairbank56
#2 Posted : Saturday, November 9, 2013 9:06:56 AM(UTC)
fairbank56
Groups: Expert
Sorry, bad transmission.
Eric
PinWizard
#3 Posted : Saturday, November 9, 2013 9:37:56 AM(UTC)
PinWizard
That was my fear. This washer is junk...thank you for your response.
