iapoppee
#1 Posted : Friday, February 8, 2008 9:19:58 AM(UTC)
iapoppee
I have a Kenmore compactor modle#665.13605790.
It compacts part way then sounds like it is stripping gears.
then I have to turn the start knob to return the ram.
Can you tell me what might cause this problem?
Thank you.
#2 Posted : Friday, February 8, 2008 4:46:39 PM(UTC)
Thank you.
There is a cycle switch on the left side of the control panel.
In what position is it?
iapoppee
#3 Posted : Saturday, February 9, 2008 2:55:47 AM(UTC)
iapoppee
It is in the normal pack position.but I have tried both and it does the exact same thing.
#4 Posted : Saturday, February 9, 2008 1:56:17 PM(UTC)
Check this switch for continuity.
When the switch is in "solid pack" position, the "O" & "O-B" circuit should be closed and the "O" & "Y" should be open.
When the switch is in "normal" position, the "O" & "O-B" circuit should be open and the "O" & "Y" should be closed.
Replace the switch if the reading is different.
In order to provide the right part number for the switch I need the color of the control panel.
iapoppee
#5 Posted : Sunday, February 10, 2008 11:42:02 AM(UTC)
iapoppee
control panel is black in color
#6 Posted : Monday, February 11, 2008 10:38:08 AM(UTC)
The part number for the cycle switch is AP3020726.
iapoppee
#7 Posted : Monday, February 11, 2008 1:09:46 PM(UTC)
iapoppee
Thanks Gene
Iwill get one and hopefuly that will fix my gear grinding compactor and make my wife a very happy camper.
#8 Posted : Monday, February 11, 2008 2:14:52 PM(UTC)
One more thing: if it's very noisy - most likely it is time for lubrication.
You can find the complete instructions in the one of my previous posts: http://forum.appliancepartspros...air-trash-compactor.html
iapoppee
#9 Posted : Sunday, April 20, 2008 10:21:48 AM(UTC)
iapoppee
Well Gene,I replaced the switch and lubed eveything.
The ram dosen't return and still sounds like stripped gears.
What now
