Discuss
jenn air Trash compactor
 in
Trash Compactor Repair
When trash compactor is running it will make a loud clanking or clicking sound. in both the up and down
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » jenn air Trash compactor
  #1 (permalink)
Old 02-01-2008, 10:24 AM
bobg7 bobg7 is offline
Junior Member
bobg7 is on a distinguished road
Default jenn air Trash compactor
When trash compactor is running it will make a loud clanking or clicking sound. in both the up and down position.
  #2 (permalink)
Old 02-01-2008, 03:20 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
When it switching from "down" to "up" - some clicking sound is normal.
Most likely it needs a maintenance and/or lubrication.
For more accurate advise I need the complete model number of the unit.
__________________
  #3 (permalink)
Old 02-02-2008, 08:40 AM
Junior Member
Default
Model NO. is TC407
  #4 (permalink)
Old 02-02-2008, 09:57 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the trash compactor from the cabinet.
Remove the drawer from the unit.
Remove one screw located under each corner of the control panel on the front of the unit.
Push the control panel upward and pull gently away to release two hooks from their slots on the unit frame.
Remove all screws holding the top cover and remove the top cover.
Lubricate the power nuts (#12 on the power screw & ram break down diagram) and the power screws (#1 on the power screw & ram break down diagram) using multipurpose lithium grease.
- Here are the break down diagrams for the Jenn Air trash compactor Model TC407B
__________________
  #5 (permalink)
Old 02-03-2008, 12:09 PM
Junior Member
Default Thanks
This is one of the best sites I haver been to. Gene, You have saved me from buying a new one. The Jennair Site was useless. Keep up the good work. People like you make this a better place to live in this great country.
Semper Fi
Bob Greenburg
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Trash Compactor not reversing. doglaw44 Trash Compactor Repair 3 01-26-2008 09:39 AM
Jenn-Air trash compactor doesn't compact nmhiggins Trash Compactor Repair 0 11-24-2007 12:56 PM
jenn air trash compactor sticks rbern007 Trash Compactor Repair 3 10-11-2007 11:34 PM
Trash Compactor MValley General Talk 1 08-17-2007 09:25 AM
