Smitty63
#1 Posted : Sunday, November 3, 2013 5:01:37 PM(UTC)
Smitty63
I replaced control board and control panel. Still doesn't work.:mad:
#2 Posted : Monday, November 4, 2013 1:35:08 AM(UTC)
Need symptoms/diagnosis of what the original problem was.
Smitty63
#3 Posted : Monday, November 4, 2013 5:05:54 PM(UTC)
Smitty63
Control panel will not light up and oven does not function. Only beeps when buttons are pressed. Ordered new control panel and control board through appliancepartspros. and installed both. Still does not work. Model # GBD277PDTO9
Smitty63
#4 Posted : Monday, November 18, 2013 4:28:14 PM(UTC)
Smitty63
Control panel will not light up and oven does not function. Only beeps when buttons are pressed. Ordered new control panel and control board through appliancepartspros. and installed both. Still does not work. Model # GBD277PDTO9 Now, we've also ordered the transformer, installed it, and the oven just beeps but will not turn on. The display board still does not turn on, nor does the oven turn on. The oven light does work. Help! SOS!
Appliance Ninja
#5 Posted : Monday, November 18, 2013 6:00:30 PM(UTC)
Appliance Ninja
If the control beeps when you press the buttons, that indicates that there is power to the control. If it is not lit up, the control is faulty. Did you replace part number W10438751? Do you have a meter to test voltage with?
Smitty63
#6 Posted : Monday, November 18, 2013 6:18:52 PM(UTC)
Smitty63
Yes I have a voltage meter. What part is W10438751
Appliance Ninja
#7 Posted : Monday, November 18, 2013 6:26:11 PM(UTC)
Appliance Ninja
That is the electronic control board at the link below.
Whirlpool W10438751 Cntrl-Elec - AppliancePartsPros.com
Smitty63
#8 Posted : Monday, November 18, 2013 6:37:17 PM(UTC)
Smitty63
I replaced the control board with 8301848
Appliance Ninja
#9 Posted : Monday, November 18, 2013 6:41:22 PM(UTC)
Appliance Ninja
That is the little board that controls the door latch. You need the large board that controls the oven, part number W10438751, available below. It is shown as number 3 in the picture below and has the whole display on it.
Appliance Ninja attached the following image(s):
Smitty63
#10 Posted : Tuesday, November 26, 2013 2:50:44 PM(UTC)
Smitty63
:) I replaced that part. Oven works know. Thanks Steve
Replacement Control Board doesn't work (Refrigerator & Freezer Repair)
by jbelina 8/9/2012 6:44:12 PM(UTC)
replacement control board doesn't work properly (Microwave Repair)
by nicht 7/3/2008 1:43:43 PM(UTC)
