I replaced control board and control panel. Still doesn't work.:mad:
Need symptoms/diagnosis of what the original problem was. |
THIS FORUM IS DEAD!!!!!!! |
Control panel will not light up and oven does not function. Only beeps when buttons are pressed. Ordered new control panel and control board through appliancepartspros. and installed both. Still does not work. Model # GBD277PDTO9
Control panel will not light up and oven does not function. Only beeps when buttons are pressed. Ordered new control panel and control board through appliancepartspros. and installed both. Still does not work. Model # GBD277PDTO9 Now, we've also ordered the transformer, installed it, and the oven just beeps but will not turn on. The display board still does not turn on, nor does the oven turn on. The oven light does work. Help! SOS!
If the control beeps when you press the buttons, that indicates that there is power to the control. If it is not lit up, the control is faulty. Did you replace part number W10438751? Do you have a meter to test voltage with?
Yes I have a voltage meter. What part is W10438751
I replaced the control board with 8301848
That is the little board that controls the door latch. You need the large board that controls the oven, part number W10438751, available below. It is shown as number 3 in the picture below and has the whole display on it. Whirlpool W10438751 Cntrl-Elec - AppliancePartsPros.comAppliance Ninja attached the following image(s):
:) I replaced that part. Oven works know. Thanks Steve
