Jack Griffin
#1 Posted : Saturday, November 2, 2013 11:42:36 AM(UTC)
Jack Griffin
Refrigerator doesn't want to run except until I thump the control panel with my fist. Then it runs until I thump it again and it stops. Clearly something is wrong with the control panel... but what? I don't know which components I should replace. Can someone enlighten me?
#2 Posted : Monday, November 4, 2013 3:59:52 AM(UTC)
Parts for Whirlpool GD22DFXFN00 Refrigerator - AppliancePartsPros.com
The most likely cause is the thermostat.
To give a little more confidence that it is bad instead of smacking the control panel just rotate the freezer thermostat up/down (not to off). If the unit firse up then I would replace the thermostat (item 9 in section 12)
Jack Griffin
#3 Posted : Monday, November 4, 2013 8:48:32 AM(UTC)
Jack Griffin
OK, I'll order the part. The refrigerator is running and won't shut off even when I smack the control panel.
Thanks.
