The dryer has the familiar scraping noise when running and I am going to order the parts (upper and lower seal).Are there any other parts I should replace? Any tricks to disassembly?
thanks
You may want to replace the rear bearing as well. The instructions are attached to the reply. - The bearing kit Part number: AP2142648
