Parts for Maytag AED4475TQ1 Dryer - AppliancePartsPros.comSee the attachment for the wiring diagram.
That it did heat and then shut off is worrisome as this may be a loose/bad connection. I am going to ignore this and perhaps we can find the problem.
Have you checked the power?
If the timer advances in timed dry with the unit running then you have the 240 volts. If it does not advance check the power. The timer motor and the heating coil run off of 240, the motor requires 120.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is good.
Unplug the unit and set it to the cycle where you do not get any heat.
Attach one meter lead to L1 and leave it there. This could be the prong on the power cord.
Now work your way back through the heater circuit. So:
Timer BK (black) should be 0 ohms
Timer B (blue) should be 0 ohms
Timer A (red) should be 0 ohms
Both sides of the Thermal Cutoff should be 0 ohms.
Both sides of the Operating Thermostat contacts should be 0 ohms. These are the outer two contacts. The inner two (violet wires) is it's internal heater and are not important here.
Both sides of the Hi Limit Thermostat should be 0 ohms.
One side of the heater should be 0 ohms. The other side should be 8 to 12 ohms.
1M on the motor should be the same as the heater resistance.
If all the above are OK then the problem is most likely the centrifugal switch on the motor or a bad connection from it to L2.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
