Wattsup
#1 Posted : Friday, November 1, 2013 7:49:01 AM(UTC)
Wattsup
Please help,
My Dryer stopped heating up so I did some research and replaced two fuses on the coil housing. I also inspected the coil for cracks or breakage, but all was good there. The machine is very clean not a lot of lint buildup inside. The hose blows is clear and blows really good and strong. Prior to replacing the two fuses on the coil housing the dryer would heat periodically then go cold. It did the same thing when I first turned it back on after replacing the fuses. If anyone can help me with this issue it would be greatly appreciated.
#2 Posted : Saturday, November 2, 2013 12:48:25 AM(UTC)
Parts for Maytag AED4475TQ1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
That it did heat and then shut off is worrisome as this may be a loose/bad connection. I am going to ignore this and perhaps we can find the problem.
Have you checked the power?
If the timer advances in timed dry with the unit running then you have the 240 volts. If it does not advance check the power. The timer motor and the heating coil run off of 240, the motor requires 120.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is good.
Unplug the unit and set it to the cycle where you do not get any heat.
Attach one meter lead to L1 and leave it there. This could be the prong on the power cord.
Now work your way back through the heater circuit. So:
Timer BK (black) should be 0 ohms
Timer B (blue) should be 0 ohms
Timer A (red) should be 0 ohms
Both sides of the Thermal Cutoff should be 0 ohms.
Both sides of the Operating Thermostat contacts should be 0 ohms. These are the outer two contacts. The inner two (violet wires) is it's internal heater and are not important here.
Both sides of the Hi Limit Thermostat should be 0 ohms.
One side of the heater should be 0 ohms. The other side should be 8 to 12 ohms.
1M on the motor should be the same as the heater resistance.
If all the above are OK then the problem is most likely the centrifugal switch on the motor or a bad connection from it to L2.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
AED4475.pdf (182kb) downloaded 2 time(s).
Wattsup
#3 Posted : Monday, November 4, 2013 7:55:50 PM(UTC)
Wattsup
I am very handy with taking things apart, replacing parts and putting things back together, but not so good with electricity. I wouldn't feel comfortable checking power with a meter unless I was on the phone or with someone that could answer my questions on the spot. I would need to buy a meter. I don't know if your allowed to be on the phone with me, but your welcome to call. Not sure how to get you my number. I don't really want to put it in a thread anyone can read.
I checked the breakers, all good. I replaced the thermal fuse ( I assume is the little white plastic fuse with the two prongs connected by two blue wires). I also replaced the thermostat next to it with two big red wires and two small purple wires connected to it. I replaced the two thermostats on the housing that contains the heater coils. And all air blows good, strong and free of lint.
The timer moves on all four settings just no heat.
I don't understand how a wire could just come loose on the motor when the machine has pretty much been sitting in one place and never moved.
I checked the L1 BK the Neutral wht, and the L2 red wires on the machine and they have a solid connection. Green and white ground wires are also solid.
Thank you for your help!!!
#4 Posted : Monday, November 4, 2013 11:56:03 PM(UTC)
Your phone number would not help at least not with me.
It is not something that I would try and talk someone through.
There are things that I do that quite frankly I do not even realize I am doing them it is just done through habit and I would not want to miss something and then you get hurt.
If you are uneasy with messing with electrical then do not do it.
Perhaps you have a friend who could check the power for you or you may have to bite the bullet and get a pro in but see below.
Since the timer advances i in all 4 modes I would say that your power is OK as it's motor requires the 240 volts to run so that is OK. Also the drum motor runs so the 120 volts is OK.
A bad/loose wire causing problems is fairly common. You may not even be able to see the problem but a meter will show it.
I still think a meter is your best bet.
It lets you check things without having the unit plugged in so is a safe way to find problems or at least narrow them down.
It is a very useful tool around the house.
For instance you replace batteries in a remote control and it still does not work. You can check the replacement batteries and find out one of them is a dud. Could save you buying a remote.
OR
You get a replacement part like a thermostat. You can check it's contacts before installing it. It is not unheard of to get parts that are bad right out of the box. This could save you many hours going around in circles when it is just a bad replacement part.
Wattsup
#5 Posted : Saturday, November 23, 2013 2:10:00 PM(UTC)
Wattsup
Hi sorry it took me so long to get back I went out and bought a meter. As for the ohms readings everything was as you instructed with an exception of one. I unplugged the dryer and tested the ohms on the timer with one meter terminal on the L1 and the other on the Black and got 0 ohms as you said, on blue also got 0 ohms and on the red I got nothing. The meter just stayed on 1.
Do you know what this would indicate?
Wattsup
#6 Posted : Saturday, November 23, 2013 7:52:14 PM(UTC)
Wattsup
Disregard previous message, I found the problem. It was tied to the red wire. I took apart the timer and found the flat copper pin that's is inside was zapped and had melted the end off so when the timer was turned to the heat setting it wasn't connecting to the red terminal so I took some needle nose pliers and bent the tip over so it would make a connection when the timer turned to the heat setting and it works great now.
Thank you for all your assistance and time. I very much appreciate it!!!!!
Wattsup
#7 Posted : Sunday, November 24, 2013 1:25:48 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
I would recommend that you replace the timer.
If the connection is not perfect it it will cause heating when current flows through it. This then further degrades the connection causing more heat and so on and so on until the connection fails.
It may melt the wire insulation/connector making the repair more difficult.
