Teammomaz
#1 Posted : Monday, October 28, 2013 7:24:56 AM(UTC)
Teammomaz
Range top and oven were working fine. Contractor moved while tiling floor. Now the only thing that works is the display panel, door lock & oven light. I set the clock.
#2 Posted : Monday, October 28, 2013 7:43:56 AM(UTC)
Check the power to/at the unit.
it sounds like everything that uses 120 volts is OK but the elements that need 240 are not getting power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Teammomaz
#3 Posted : Monday, October 28, 2013 9:04:16 AM(UTC)
Teammomaz
If OK
If OK
Thanks. I tried the breaker suggestion; everything is as it was before. Will get a friend/electrician to do the next part.
Samsung Range and Oven Won't Heat Up (Oven Repair (including Ranges and Cooktops))
by neweyess 8/19/2013 5:13:28 AM(UTC)
Range and Oven not working (Oven Repair (including Ranges and Cooktops))
by NamiSwaaan 2/25/2011 10:46:14 AM(UTC)
magic chef drop in RV range and oven (Oven Repair (including Ranges and Cooktops))
by ken_cheriii@yahoo.com 11/28/2008 8:29:02 AM(UTC)
