adam120674
#1 Posted : Sunday, October 27, 2013 3:23:15 PM(UTC)
adam120674
I cut a hole in my mini fridge. Need to run soda lines in to a cold plate I have in the fridge. Didn't see anywhere where I cut a line or anything. I hear "air coming from the hole I cut. I don't know a lot about refrigerators but I figured if I miss the coolant lines I'll be OK. Thanks for any help. It's a Haier 2.7cfUserPostedImage UserPostedImage
adam120674
#2 Posted : Sunday, October 27, 2013 3:41:05 PM(UTC)
adam120674
Air stopped shortly after I drilled the hole.Then it starts coming out when I plug it back up again.Then stopped about 30 seconds later. could it be the fan just blowing between the foam insulation and the metal casing?
