AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer starts and stops if I hold timer knob it stays on
Dryer works sometimes have to wiggle timer knob dryer has starter button and timer knob :mad:
Here are your parts Parts for Maytag NED5800TQ0 Dryer - AppliancePartsPros.comSince wiggling the timer knob can start the unit, I would say that it needs replacing. You could check this with a meter. See the attachment for the wiring diagram. Set the timer to where it will not start. Unplug the unit. Check that the BU/BK contacts are 0 ohms. Use the most sensitive meter scale and short the meter leads together before measuring so you know if there is a zero offset in the meter. If it is not 0 ohms replace the timer. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
