Machine only had maybe 3 complete wash cycles when we had a power surge, all buttons quit working confirmed the control board was fried. Replaced the board with WD21X10247, seemed to work then I noticed after more than an hour unit was still running. I started a rinse cycle and things sound like it was working fine I can hear it fill rinse and drain, after that it starts over...
Not sure if it starts cycle over or if it's just the pump running, I'll post an update when I get it figured out.
Originally Posted by: bassman23601 Not sure if it starts cycle over or if it's just the pump running, I'll post an update when I get it figured out. Starts complete cycle over again, only stops when I shut the unit down
