bobscan
#1 Posted : Monday, October 21, 2013 12:15:22 PM(UTC)
bobscan
ordered replacement pump AP28263484
Have issue with wiring existing pump on dishwasher has a blue wire connected to one side of the capacitor . New motor has no terminal for blue wire.
Is this the correct motor?
What do i do with wire?
jwicklin
#2 Posted : Tuesday, October 29, 2013 11:37:50 AM(UTC)
jwicklin
For this model the violet wire goes from terminal 3 of the circulation motor to terminal 2 of the door switch. There should be a black wire on the dishwasher (comes from control board) that you need to connect to terminal one of the motor. Those two wires and the green ground wire are all that you should have to disconnect / connect when replacing the motor & capacitor as a unit.
Terminals 2 & 3 of the motor are common to each other. There should be a spade connector that has two wires one of these wires leads to one terminal of the capacitor the other wire goes to the motor windings. Wiring diagram doesn't list colors for these (presumably because motor and capacitor are purchased together and thus come prewired). This spade connector per the diagram should be connected to terminal 2 of the motor. The wire coming from the other side of the capacitor goes to the other side of the motor windings. I don't think these capacitors are polarized however if you do see a negative terminal marking that side of the capacitor should be connected to the wire going to terminal 2 of the motor since 2 & 3 are connected to each other and 3 is routed to the negative side of the power switch.
Circulation Pump (Dishwasher Repair)
by JMH18 1/7/2018 6:09:03 AM(UTC)
Kitchen Aid Stand Alone Ice Machine Recirculation Pump Question (Refrigerator & Freezer Repair)
by hokiehivpi 10/25/2017 6:49:53 AM(UTC)
Whirlpool dishwasher - circulation pump? (Dishwasher Repair)
by Downtown 12/1/2015 4:08:35 PM(UTC)
Fridgidaire Circulation Pump Issues (Dishwasher Repair)
by dkon 5/28/2015 7:33:44 AM(UTC)
Bench test bosch circulation pump? (Dishwasher Repair)
by Jlagraff 4/16/2013 9:18:11 PM(UTC)
Bosch SHE68M06UC/50 Circulation pump replacing help (Dishwasher Repair)
by samchi 3/13/2013 6:01:37 PM(UTC)
Cannot remove Bosch circulation pump! (Dishwasher Repair)
by tony2222 1/20/2013 10:29:53 AM(UTC)
circulation pump on a Frigidaire dishwasher (Washer Repair)
by weesel72 12/14/2012 10:17:28 AM(UTC)
by Mark Rininger 4/17/2012 12:01:54 PM(UTC)
Circulation Pump not working (Dishwasher Repair)
by Rick in Pittsburgh 1/11/2012 4:43:41 PM(UTC)
Does this sound like a Circulation Pump problem? (Dishwasher Repair)
by Pinebear 10/18/2011 8:44:07 AM(UTC)
Wiring for circulation pump Prt # AP2802385 (Dishwasher Repair)
by lstein4 2/28/2011 2:32:25 PM(UTC)
Troubleshooting a Kitchenaid circulation pump (Dishwasher Repair)
by dg0993 10/22/2010 10:20:37 AM(UTC)
Replacing a Bosch Circulation Pump for Dishwasher (Dishwasher Repair)
by sabphi 12/25/2009 11:33:49 AM(UTC)
Bosch Circulation pump, low flow but nothing visably wrong. (Dishwasher Repair)
by Terry O'Brien 6/7/2009 2:08:05 PM(UTC)
