KJKJ22
#1 Posted : Monday, October 21, 2013 12:14:13 PM(UTC)
KJKJ22
For the last several months, my Whirlpool Quiet Partner II won't dry the dishes. When it gets to the Clean cycle the green light flashes repeatedly. When I open the door the temperature of the air is very hot but the dishes are dripping wet and I end up letting them air dry overnight with the door open. Other than this issue the dishwasher works fine. Any suggestions for diagnosing what part may be malfunctioning?
Thanks!
HumboldtRepairMan
#2 Posted : Monday, October 21, 2013 4:34:32 PM(UTC)
HumboldtRepairMan
Check to make sure you have 120v going to the element during the dry cycle and continuity test the heat element make sure it's 60 ohms or less............if those 2 check out ok then you possibly have a problem with the main board that's intermittent or a wire harness/connection issue.
