Hello,
I have an LG LMX25964ST refrigerator that is not cooling. 1. it has power. 2. I can hear the fans running. 3. the compressor is running.
can i get some assistance on what the issue may be or where to look? In the past I would think it was a relay switch to the compressor but with these new appliances i am not sure.
Here are your parts Parts for LMX25964ST - AppliancePartsPros.comSince the compressor is running and the freezer is not getting any cooling at all, you have a sealed system problem. This will be an expensive repair as you need a pro. Often it makes more sense to put those dollars towards a new unit. Check your warranty as some uniots have a longer warranty on the sealed system. |
THIS FORUM IS DEAD!!!!!!! |
