Rdizzy
#1 Posted : Thursday, October 17, 2013 7:09:04 AM(UTC)
Rdizzy
Hello,
I have an LG LMX25964ST refrigerator that is not cooling.
1. it has power.
2. I can hear the fans running.
3. the compressor is running.
can i get some assistance on what the issue may be or where to look?
In the past I would think it was a relay switch to the compressor but with these new appliances i am not sure.
#2 Posted : Friday, October 18, 2013 3:16:38 AM(UTC)
Parts for LMX25964ST - AppliancePartsPros.com
Since the compressor is running and the freezer is not getting any cooling at all, you have a sealed system problem.
This will be an expensive repair as you need a pro.
Often it makes more sense to put those dollars towards a new unit.
Check your warranty as some uniots have a longer warranty on the sealed system.
