johngrim
#1 Posted : Monday, October 7, 2013 6:29:03 AM(UTC)
johngrim
dishwasher door will pop open after washer has run for 50:00 minuets when I close door washer will run for a short time and door will pop open again
HumboldtRepairMan
#2 Posted : Monday, October 7, 2013 3:45:03 PM(UTC)
HumboldtRepairMan
Possible problems with your unit:
-Unit is leaning forward and is not perfectly level in all directions. Unit should be level from left to right and front to back-Worst mistake you can do is have your door leaning forward that will cause a possible leak through time also.
-Bad or weak door springs or bend/damaged door.
-Bad door lock & latch kit.
-Dishes/utensils pushing against the door being overpacked
Your parts
Parts for Whirlpool KUDS01FLWH6 Dishwasher - AppliancePartsPros.com
