dishwasher door will pop open after washer has run for 50:00 minuets when I close door washer will run for a short time and door will pop open again
Possible problems with your unit: -Unit is leaning forward and is not perfectly level in all directions. Unit should be level from left to right and front to back-Worst mistake you can do is have your door leaning forward that will cause a possible leak through time also. -Bad or weak door springs or bend/damaged door. -Bad door lock & latch kit. -Dishes/utensils pushing against the door being overpacked Your parts Parts for Whirlpool KUDS01FLWH6 Dishwasher - AppliancePartsPros.com
