Fan
Flextone
#1 Posted : Sunday, October 6, 2013 4:08:20 AM(UTC)
Flextone
I bought a Jenn air W130W-C wall oven and I'm making a cabinet for it but I notice it has a fan in the top corner at the back of the oven does this fan need to be exausted out side? Also I can't seem to find how many amps it is? Thanks
#2 Posted : Sunday, October 6, 2013 5:56:00 AM(UTC)
Parts for Jenn-Air W130W-C Wall Oven - AppliancePartsPros.com
Here is a dimension guide
http://www.maytag.com/digitalas...Guide%20-%2009912744.pdf
Looking at the parts breakdowns I would say that the fan does not have to be vented it is just a cooling fan.
Looks like the maximum draw is 24.6 amp.
I would check your local electrical code as to what wire and breaker size is required.
Also I would not build a cabinet unless you have already checked that the unit is fully functional.
As you can see in the parts breakdowns that many parts for this unit are obsolete and no longer available.
Flextone
#3 Posted : Sunday, October 6, 2013 5:18:42 PM(UTC)
Flextone
thanks so much Denman for your reply it helped alot
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GE GTH18ECTZRWW evaporator fan issue (Refrigerator & Freezer Repair)
by snakeeyesma81 4/30/2024 4:44:21 PM(UTC)
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 4/29/2024 12:37:29 PM(UTC)
Frigidaire Evaporator Fan (Refrigerator & Freezer Repair)
by KevN1974 4/13/2024 11:03:34 AM(UTC)
replacement for discontinued GE convection fan motor? (Oven Repair (including Ranges and Cooktops))
by evofxdwg 4/11/2024 11:12:12 AM(UTC)
Kenmore/Whirlpool GB22DKXJW00 - evap fan replacement no ground (Refrigerator & Freezer Repair)
by DIY2024 3/24/2024 1:07:07 AM(UTC)
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Continuously running evaporator fan (Refrigerator & Freezer Repair)
by gjgogol 2/26/2024 6:47:30 AM(UTC)
kenmore fridg 363.9532750 fan seems to run to much (Refrigerator & Freezer Repair)
by jim97 2/24/2024 7:19:40 AM(UTC)
Compressor & condenser fan not running - low voltage, start relay ok (Refrigerator & Freezer Repair)
by Guest 1/17/2024 11:51:38 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
LG french door refrigerator ice maker fan not working (Refrigerator & Freezer Repair)
by md5757 11/6/2023 11:27:11 AM(UTC)
Jenn-Air SVE47500B Cooling Fan Running at Low Temps (Oven Repair (including Ranges and Cooktops))
by hillridge 9/26/2023 9:04:30 AM(UTC)
GE Monogram ZV800SJ1SS Reduced Fan Speed (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 8/28/2023 2:09:18 PM(UTC)
