I bought a Jenn air W130W-C wall oven and I'm making a cabinet for it but I notice it has a fan in the top corner at the back of the oven does this fan need to be exausted out side? Also I can't seem to find how many amps it is? Thanks
Rank:: Advanced Member
Here are your parts Parts for Jenn-Air W130W-C Wall Oven - AppliancePartsPros.comHere is a dimension guide http://www.maytag.com/digitalas...Guide%20-%2009912744.pdfLooking at the parts breakdowns I would say that the fan does not have to be vented it is just a cooling fan. Looks like the maximum draw is 24.6 amp. I would check your local electrical code as to what wire and breaker size is required. Also I would not build a cabinet unless you have already checked that the unit is fully functional. As you can see in the parts breakdowns that many parts for this unit are obsolete and no longer available. |
THIS FORUM IS DEAD!!!!!!! |
thanks so much Denman for your reply it helped alot
