Karen Hoskins
#1 Posted : 12 years ago
Karen Hoskins
Set washer to 10 minute wash. Washer fills, agitates aporx. 2 to 3 minutes; then it starts spinning & spraying more water. Water over fills tub & leaks out over the top of tub. Pulled off the front washer panel to watch the tub & see what machine does. When I stopped it & put it on spin, water drained. It works fine on the rinse cycle. The wash cycle is the only problem. Thinking it's the wash timer. If this needs replaced, how hard is this to do, and will I need a diagram?
Karen Hoskins
#2 Posted : 12 years ago
Karen Hoskins
Originally Posted by: Karen Hoskins Go to Quoted Post
Set washer to 10 minute wash. Washer fills, agitates aporx. 2 to 3 minutes; then it starts spinning & spraying more water. Water over fills tub & leaks out over the top of tub. Water is not soapy. Pulled off the front washer panel to watch the tub & see what machine does. When I stopped it & put it on spin, water drained. It works fine on the rinse cycle. The wash cycle is the only problem. Thinking it's the wash timer. If this needs replaced, how hard is this to do, and will I need a diagram?
Older Kenmore Washer leak (Washer Repair)
by Guest about a year ago
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino about a year ago
Washer leak Frigidaire Affinity (Washer Repair)
Washer leaks at end of cycle only (Washer Repair)
by Orvilejulius 2 years ago
Kenmore Elite 665.13929K015 Dishwasher Leak (Dishwasher Repair)
by JROTN 2 years ago
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 3 years ago
Old Maytag 712 Washer Leaking at Injector Valve (Washer Repair)
by ronp99 3 years ago
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 3 years ago
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 3 years ago
LG WM3570HWA Washer Leak (Washer Repair)
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 3 years ago
Maytag dishwasher leaking and smoking (Dishwasher Repair)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4 years ago
dishwasher leak varies (Dishwasher Repair)
by scottsasa 4 years ago
Delayed dishwasher leak (Dishwasher Repair)
by budflanksteak 4 years ago
