Karen Hoskins
#1 Posted : Monday, September 23, 2013 10:16:01 AM(UTC)
Karen Hoskins
Set washer to 10 minute wash. Washer fills, agitates aporx. 2 to 3 minutes; then it starts spinning & spraying more water. Water over fills tub & leaks out over the top of tub. Pulled off the front washer panel to watch the tub & see what machine does. When I stopped it & put it on spin, water drained. It works fine on the rinse cycle. The wash cycle is the only problem. Thinking it's the wash timer. If this needs replaced, how hard is this to do, and will I need a diagram?
Karen Hoskins
#2 Posted : Monday, September 23, 2013 10:21:32 AM(UTC)
Karen Hoskins
Originally Posted by: Karen Hoskins Go to Quoted Post
Set washer to 10 minute wash. Washer fills, agitates aporx. 2 to 3 minutes; then it starts spinning & spraying more water. Water over fills tub & leaks out over the top of tub. Water is not soapy. Pulled off the front washer panel to watch the tub & see what machine does. When I stopped it & put it on spin, water drained. It works fine on the rinse cycle. The wash cycle is the only problem. Thinking it's the wash timer. If this needs replaced, how hard is this to do, and will I need a diagram?
Older Kenmore Washer leak (Washer Repair)
by Guest 2/1/2024 9:56:27 AM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Washer leak Frigidaire Affinity (Washer Repair)
by Guest 10/23/2023 1:59:44 PM(UTC)
Washer leaks at end of cycle only (Washer Repair)
by Orvilejulius 8/13/2023 8:42:38 PM(UTC)
Kenmore Elite 665.13929K015 Dishwasher Leak (Dishwasher Repair)
by JROTN 12/22/2022 5:12:45 PM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Old Maytag 712 Washer Leaking at Injector Valve (Washer Repair)
by ronp99 9/11/2022 1:40:40 PM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
LG WM3570HWA Washer Leak (Washer Repair)
by Guest 4/4/2022 12:38:34 PM(UTC)
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 2/27/2022 1:15:02 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
dishwasher leak varies (Dishwasher Repair)
by scottsasa 1/3/2021 4:23:28 AM(UTC)
Delayed dishwasher leak (Dishwasher Repair)
by budflanksteak 12/11/2020 5:03:57 AM(UTC)
