mbalster27
#1 Posted : Friday, September 20, 2013 4:21:16 PM(UTC)
mbalster27
Bought a dishwasher off of Craigslist and was told it had a problem draining completely. However, when I hooked it up it went through the wash cycle for about 10-15 minutes and then water started pouring out the front of the dishwasher all over my kitchen. It was a lot of water. So my question is, am I needing a pump or do I need to be considering a completely different part?
HumboldtRepairMan
#2 Posted : Friday, September 20, 2013 6:15:10 PM(UTC)
HumboldtRepairMan
you need to look at the unit as it's running and find where the leak is coming from.
mbalster27
#3 Posted : Friday, September 20, 2013 6:49:39 PM(UTC)
mbalster27
It leaks out along the bottom of the door and no where else from what I can see
HumboldtRepairMan
#4 Posted : Saturday, September 21, 2013 8:22:38 AM(UTC)
HumboldtRepairMan
Make sure the unit is level all the way around first..........if it's leaning forward it will leak.
mbalster27
#5 Posted : Sunday, September 22, 2013 3:23:41 PM(UTC)
mbalster27
It's level, it doesn't leak it actually pours out of the dishwasher.
