:mad: I have a 2003 Frigidaire Side by Side Refrigerator that is now freezing the food on the refrig side. I took everything out, turned it off, cleaned it and put all the shelves back in. I then placed three cups of water on the shelves; one at the bottom, one in the middle, and one at the top. I turned the freezer and refrig back on to 2. The freezer started freezing the food and the refrig was cool but not freezing. I then turned the refrig and freezer up to 3. Now the water is freezing in the refrig. The freezer seems to be working fine. I see a hole in the back of the refrig behind the veggie drawer. I looked back there and felt the coils. Is there suppose to be a door on that opening? Knowing my luck it's going to be the $200.00 part that I need to replace. Any ideas?
I have since removed the back panel and vacuumed and blown out all the dust. OMG. Have replaced the cups of water in the refrig and will see what happens. The fan is working but I don't know where to look for the damper control. Any help would be appreciated. Thanks.
It's been about 3 hours since I did the above. The water is freezing in the top cup but not the middle or bottom. Does this mean the control ($200.00) part is the culprit?
What did you do to fix it ?
