TylerC78
#1 Posted : Tuesday, September 17, 2013 1:49:06 PM(UTC)
TylerC78
I have an older upright freezer probably 30+ years old. It quit and warmed up the other day, so I cleaned it out turned off the thermostat unplugged it and left. Now If I turn it on it will kick on fine and freeze great for about an hour then shut off and never never come on again unless I turn thermostat off and back on again. Then same issue. I noticed that it did get hot on the outside coils on the back and the compressor, but I figured it was just working hard to get the temp down initially. Any thoughts??
#2 Posted : Wednesday, September 18, 2013 2:46:11 AM(UTC)
I cannot find any info on this unit.
Please check your model number.
Instead of shutting the unit down try moving the thermostat up/down a little.
if the unit fires up then it is probably the thermostat (sticking open)
TylerC78
#3 Posted : Wednesday, September 18, 2013 8:52:51 AM(UTC)
TylerC78
I double checked and that is the correct model number listed on the door. I thought that it might be a faulty thermostat. But wasn't sure why everything would shut off permenantly. Is the compressor overheating and shutting itself down then?
#4 Posted : Wednesday, September 18, 2013 12:33:32 PM(UTC)
[COLOR="Blue"]Is the compressor overheating and shutting itself down then?[/COLOR]
I cannot say but usually if a compressor overheats it will reset once it cools a bit and try tostart again so it is constantly clicking every couple of minutes.
