Miguel*Paredes
#1 Posted : Tuesday, September 17, 2013 12:58:43 PM(UTC)
Miguel*Paredes
I would like to know if the compressor is actually bad. Each of the terminals: common, start, and run gives me 4 Ohms which would indicate a short winding, but I wonder if this would also apply to such compressor because the compressor label reads "3PH".
#2 Posted : Wednesday, September 18, 2013 3:08:59 AM(UTC)
Parts for Whirlpool GC5SHEXNS03 Refrigerator - AppliancePartsPros.com
See the attachment for the tech sheet
Here is a service manual.
Although your model number is not shown in the manual it should be a close match.
You will have to join the site to be able to download the manual.http://appliancejunk.com...&id=214;t=1379501815
Yur are correct that these compressors are different.
There are not separate start and run windings.
Your 4 ohms seems a little low.
Did you short the meter leads together before starting, so you can see if there is some zero offset in the unit.
File Attachment(s):
GC5SH.pdf (822kb) downloaded 3 time(s).
