jeraza
#1 Posted : Tuesday, September 17, 2013 12:35:59 PM(UTC)
jeraza
I just can't budge frozen nuts on star burners. Tried penetrating oils, etc... but no luck... I can remove unit and get access to insides by removing sides etc.. I need to replace (3) Ignition Plug Assembly units and the Spark Igniter Module. Can I install the Spark Plug Thingy's with front/side access only ??? Or do I have to drill out the star burner nuts etc...?
HumboldtRepairMan
#2 Posted : Tuesday, September 17, 2013 3:58:10 PM(UTC)
HumboldtRepairMan
If you tried oil then your only resort is to drill them out and replace them with a nice steel bit......they heat and cool and seize on sometimes that's just a range for you it's a common problem.
jeraza
#3 Posted : Tuesday, September 17, 2013 9:10:09 PM(UTC)
jeraza
Thank you for the reply... If I choose not to drill out the star burner nut can I replace the Ignition plug assembly and ignition spring with only front or side access ?
Guest (4)
