bobcraycraft
#1 Posted : Sunday, September 15, 2013 5:23:18 AM(UTC)
bobcraycraft
After a new floor installation, I came home to find my Kenmore cooktop/oven 's electornic control display blank. When turning on one of the burner control knobs, I get a with a "PF <time>" display. Normally, you just hold the "Off/Cancel" button and everything is fine.
Now, the PF goes off and you can set the time, but as soon as you turn the burner control knob off, the display goes blank. At no time do the heating elements heat, even though the "Cooktop On" light lights up.
The oven is the same, once any burner is turned on, you can set the oven temperature and start it, the PreHeat light even comes on, but the oven does not heat.
I have tried turning on the "Oven Lockout" function and turning it back off with no luck. My users manual references a Cooktop Lockout but I can find no instructions in the manual how to activate/deactivate it.
I am guessing that the flooring guys gave the unit a hard landing when moving it and I have an electrical damage. Trying to avoid a service call from Sears.
Thanks,
Bob Craycraft
Washington,DC
#2 Posted : Monday, September 16, 2013 3:38:08 AM(UTC)
Your model number is incomplete.
Kenmore numbers are usually 3 digits, a period and then an additional 8 digits.
I agree with you that is sounds like a power problem.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
