Does your part AP3882915 control the defrost cycle? If not which part does? Thanks for your reply.
Here are your parts Parts for Whirlpool GD5RHAXSS00 Refrigerator - AppliancePartsPros.comSee the attachment for the tech sheet. [COLOR="Blue"] Does your part AP3882915 control the defrost cycle?[/COLOR] No this is just the user intrface [COLOR="Blue"] If not which part does?[/COLOR] The main control board (item 18 in the Unit Parts section) (AP4334025) You did not say exactly what the problem or symptoms were. A defrost problem can be the board, the heater or the defrost thermostat. |
THIS FORUM IS DEAD!!!!!!! |
