AppliancePartsPros.com
Appliance Repair Help
New ignitor draws too much current; will it cause the Safety Valve to not open?
I have an oven that doesnt work.. I ordered a new ignitor and it still doesnt work..Using an AC current probe to measure.. the old ignitor was showing 2.75 after about a minute, wouldnt go any higher. I read somewhere that the range should be 3.2 to 3.6 for it open the valve. When the new ignitor came in I installed it and the oven still doesnt work. The AC current goes to 3.79 after a half a mintute and stays there.
My question is would an value over 3.6 amps cause the valve to not open? Is this a faulty ignitor? Has anyone ever heard of a case like this?
It's usually a minimum of 3 amps to release the safety valve.........sounds like you have an issue with the safety valve not the ignitor..... Heres a video to help Oven Safety Valve Testing - YouTube
I tried replacing the valve (actually just laying the new valve alongside the existing one and connecting the wires and listening/feeling the new valve) and it doesnt open or close either when the ignitor gets red hot and the current reading is 3.79 Amps. Could my problem be a defective ignitor? Or should I look at something else?
Check main valve (first in line connected to wall supply hose) on the unit and see if you turned or bumped the switch off there's a flipswitch that turns the gas off going to the oven area.
Originally Posted by: HumboldtRepairMan  Check main valve (first in line connected to wall supply hose) on the unit and see if you turned or bumped the switch off there's a flipswitch that turns the gas off going to the oven area. Where would this main valve be? Near the Top of the stove? The burners on top work fine.. does this valve only control gas to the oven?
Read my post........................from the supply line from the wall follow it to unit that's the main valve or regulator first thing on unit
