I have different error codes that flash randomly in the display... they rotate from 78, 77, 74, 73.. then code 33 remains on the screen for a bit, and then others begin rotating again.
The dishwasher is still running regular cycles and doesn't seem to be having operational problems.
What needs to be done?
Mike
Check under unit and see if you see any small leaks on the bottom side of this unit. Sometimes they leak and give numerous random codes from a small hose leak.
