MIKE801
#1 Posted : Monday, August 26, 2013 11:13:43 AM(UTC)
MIKE801
I have different error codes that flash randomly in the display... they rotate from 78, 77, 74, 73.. then code 33 remains on the screen for a bit, and then others begin rotating again.
The dishwasher is still running regular cycles and doesn't seem to be having operational problems.
What needs to be done?
Mike
HumboldtRepairMan
#2 Posted : Monday, August 26, 2013 7:14:20 PM(UTC)
HumboldtRepairMan
Check under unit and see if you see any small leaks on the bottom side of this unit. Sometimes they leak and give numerous random codes from a small hose leak.
