josiec
#1 Posted : 11 years ago
josiec
dryer runs fine only if you hold the start knob
#2 Posted : 11 years ago
Parts for GE GTDP300EM0WS Dryer - AppliancePartsPros.com
Sounds like a bad motor.
The motor has two centrifugal switches which activate when the it gets close to operating speed.
One of then closes and connects in the heating coil. This ensures that the heater does not come on before there is air flow.
The other one has two functions.
It open a set on contacts and disconnects the motor's start winding as leaving this on all the time would overheat the motor.
It also closes a set of contacts and provides a circuit path which is in parallel with the start switch. This lets you let go of the start switch and the motor continues to run. It sound like this is not working.
GE electric dryer (DCVH680EJ1MS) Stops 2 mins. Into Cycle (Dryer Repair)
by bjohns610 5 years ago
GE electric dryer rotating switch (Dryer Repair)
by pamelaw72 5 years ago
GE Electric Dryer Shuts Off Mid-Cycle (Dryer Repair)
by Dynocon 9 years ago
GE Electric Dryer - Belt / slide fix, did I break something? (Dryer Repair)
by bmilcs 9 years ago
GE electric Dryer running then had a smell and stopped (Dryer Repair)
by DDEAN 10 years ago
GE Electric Dryer won't start (Dryer Repair)
by brosnan 10 years ago
GE electric dryer won't heat up (Dryer Repair)
by jrogers 12 years ago
GE Electric Dryer suddenly got loud (Dryer Repair)
by Newbie2 12 years ago
GE Electric Dryer - Won't Start (Dryer Repair)
by stockejj 12 years ago
GE Electric dryer no start (Dryer Repair)
by TravisG 14 years ago
GE electric dryer wont start (Dryer Repair)
by cojay 14 years ago
trouble replacing belt GE Electric Dryer (Dryer Repair)
by lshelly40 14 years ago
GE Electric dryer, no heat (Dryer Repair)
by khoshkkon 14 years ago
Ge Electric Dryer Start Switch (Dryer Repair)
by lwpeters52@hotmail.com 14 years ago
Maytage Electric Dryer keeps shutting down (Dryer Repair)
by rwnoble 14 years ago
